fxdx front end wobble 80mph+
Just did steering head bearings and rebuilt front forks and now it wobbles? I'd guess that's where your problem is, with proper steering head bearing adjustment and installation being the first thing I'd check. Also, just because a part is new doesn't mean it's right.
Lowering the rear increases rake which increases straight line stability. Millions of guys have put on shorter rear shocks without causing front end wobbles.
wobble on fxdx ....
ive had one experiance with death wobble at 100mph ....start from *** end of bike working forward to rectify problem! ie rear axle /bearings tire/wheel/air/balance etc...shocks/ mounts/swingarm etc....you get the picture.trust me it is the only way to diagnose problem...had an old biker (1%er) tell me this: front end wobble check your *** end ,*** end wobble check your front end ....if both wobble ,your too damn drunk to ride
has anyone found a solution. also do you guys that are experiencing this issue have stock drag bars of aftermarket apes.
i have the same wobble at around 70-75 it starts to go left to right and it started only after i installed my apes never did this when i had stock drag bars. everything mentioned above and in other forums checks out right what can this be???
I had a bad tire once
I had a bad front tire once that would shake at similar speeds and actually create a bar slap on my ninja. It was invisible on the balancer and didnt show any odd wear signs either. I just said screw it and bought new rubber front and rear and fixed the problem. I mount all of my own tires and NEVER balance a motorcycle tire and out of about 30 sets of tires only 2 had to be balanced due to poor tire quality. Considering the speeds I rode i would definitely say balance will never cause a wobble as its an up and down problem and not a lateral issue. I am also a firm believer in the True Track kit as well. I love my street bob but man they arent right from the factory. New tires and a True Track is my vote.
