popping on decel
popping on decel
I did a search and found many results. Not really any for a 05 superglide. I have a se air cleaner kit and se slip-ons. Have a lot of popping or what almost sounds like a backfire when I decel. I don't think there are any exhaust leaks. The header pipes are stock. As far as I know they were never taken off. Could it be the pipes? I really don't like it. Kinda sounds like crap. Any suggestions?
It is carbed, and I meant a '95, not '05. Sorry. I'm thinkin' it may be the type of slip ons. It did it with and without the baffles. I'll pull the plugs and see what color they are and go from there for tuning. I was told it was jetted, but was told it was rich. It doesn't look like it takes much to check.
been back and forth on this myself went to BCT baffles in the V&H sideshots for a bit but lost top end so I have now gone back to V&H stock baffles (loud as all f__k) so now I get popping on decel, and sometimes on gear change.
My work around is to keep revs in the range where i don't get it unless I don't really care (running hard etc) kept the top end power and only have to take it easy in the mornings leaving home.
Pulls hard all the way through the range, and is tuned with Vtune so I know its spot on.
Its really a taste thing.
chevdude
Exhaust System Topics
07-13-2007 01:34 AM
