rear relocation kit necessary?
I have ordered a backrest, luggage rack, docking hardware and quick disconnect sideplates for my '08 Wide Glide. Is the signal light relocation kit necessary also if I'm not installing saddlebags please? The PDF instruction manual says the relocation kit may possible be needed, it didn't say it is for sure.
It's after hours or I'd phone the dealership and verify if the relocation junk is necessary, thanks in advance.
HUH?
As I recall they are wired the same, you are just routing the wires differently. On my 05 it did relocate where they were mounted, to the farthest back hole on the struts.
There are (2) relocate kits. One moves the lights to the rear.
The other moves the signals out and inserts mounting device..
You will need one or the other. Or fab your own set-up..
If I were you I'd just go for the move to the rear, and get it over with.
You may want quick detach bags someday..
kaisers81
10-22-2017 05:13 PM
