Manual override for alarm
Old 05-28-2010 | 12:32 AM
Orange's Avatar
Orange
6th Gear
Question Manual override for alarm
Hi folks. I've just bought a 2008 FXD which came without an owner's manual, and I want to find out how to set the code for the alarm and also how to manually override the alarm in the event of it being set off by a bluetooth phone or whatever. Can anybody help? Thanks.
Old 05-28-2010 | 07:55 AM
HDTech74's Avatar
HDTech74
never heard of it being set off by bluetooth.
unless you know the PIN for the security, you'll never over ride it.
secutiry on a dyna makes no sense. you need the key to start it.
not like touring or softail where you can leave the ignition unlocked and
walk away with the fob.
It's easier at the dealer to have the hook it up to the digital tech and
reset a pin for you and to program the fobs.
You can't program the fobs at home.
Buy and owners manual and a service manual, money well spent.
there are 2 service manuals, the regular and the electrical, the electrical
has alot of pages about security.
Old 05-28-2010 | 08:18 AM
jaqmes's Avatar
jaqmes
there is a sequence to follow pm me for details
Old 05-28-2010 | 08:43 AM
HDTech74's Avatar
HDTech74
yeah, the sequence is USELESS unless you know the PIN to OVER RIDE it.
Old 05-28-2010 | 09:34 AM
jaqmes's Avatar
jaqmes
if you have the key,fob you can bring up the pin and change it
Old 05-28-2010 | 10:43 AM
tab69pr's Avatar
tab69pr
if you have a working fob for the bike there is a sequence you can enter to change the pin. holla if you need it!
Old 05-28-2010 | 12:11 PM
Newhawk's Avatar
Newhawk
Setting security PIN nmber.
To start your bike using the security code (you must know the code if you dont have your FOB).
But if you have the FOB you can change the code at anytime even if you dont know the pin, read below.
the code is a 5 digit number 1-9
disarming the alarm: (With the known pin)
Turn on the ignition, (do not shake the bike or turn the stearing or raise it off its stand) quickly hold down both turn signals until the Key Icon flashes at a high rate in the odemeter window (5 flashes).
enter first digit of your pin by pushing the left turn signal until the first digit shows in the odometer, once the correct digit is reached, press the right turn signal 1 time to store it.
enter second digit of your pin by pushing the left turn signal until the second digit shows in the odemeter, once the correct digit is reached, press the right turn signal 1 time to store it.
continue doing this until you have entered all 5 digits of your pin. once you have entered the 5th digit and stored it by hitting the right turn signal once, the key icon will stop flashing, you can now mount, start and ride your bike.
if you do not know your pin number, but you have a FOB, you can change the number right now. FOB must be present to perform pin change.
select a number with 5 digits 1-9 that you can remember and nobody else will know. write this number down on your card.
Turn the ignition ON OFF ON OFF ON
Press left turn signal switch 3 times
Press right turn signal 1 time and release
Turn signals will flash 3 times and The current pin number will appear in the odometer, the first digit will be flashing.
enter the first new digit of your new pin by pressing the left turn signal X amount of times. once happy with the digit, press and release right turn signal.
enter the second new digit of your new pin by pressing the left turn signal X amount of times. once happy with the digit, press and release right turn signal.
After you enter the 5th digit and store it by pressing and releasing the right signal button, turn the ignition off before the security system rearms itself, This stores the new number, you have now changed your pin.
its fairly easy to do.
Old 07-16-2010 | 09:49 AM
trapper_canada's Avatar
trapper_canada
You can do that with the Dyna as well. I had my FOB beside my bike...started it and went to town. Turned off the bike and couldn't restart it cause I didn't have the FOB.
Old 07-16-2010 | 11:46 AM
eviljason's Avatar
eviljason
IS there any way to permanently disable the security system?
Old 07-16-2010 | 04:36 PM
Taddeoeg's Avatar
Taddeoeg
Just pull out the TSSM and replace it with a TSM. You may have to "marry" the TSM to the ECM but procedures are available in the Service Manual.
If you have a TSSM and matching fobs you want to get rid of, I'd be interested in trading you my standard TSM if our bikes are compatible. Otherwise the TSM will run you about $125 (I believe) from Zanottis or you might find one on eBay.
Quick Reply: Manual override for alarm
