Any Advice?
Any Advice?
I have an 06 Lowrider, and need a some help with an issue, the other day i went out for a little cruise, and now when i was going up a hill, i started to give it a little more to keep at cruising speed, while going up ive been having pinning issues and it started pinning all but halfway up the hill and then finally stopped like that, and when it stopped pinning, its like i lost a cylinder or something, i lost power going up, i gave it more gas to get up the hill but i wasnt gaining no speed, just losing it. Am i having injector problems? i dont know it started to freak me out like the bike was going to die, but what was weird is i turned off the road onto another road and when i made my turn i had full power again all the way home, couldnt make it ping at all on the way back, which i could do when going down the highway at 60 just crack on it ..........what the heck is going on????
Welcome to HDF from the UK. First rule, if it starts pinging ease off the throttle or change down a gear. You risk doing serious damage inside the engine if you let it ping like that.
I suggest you ride the same route again and if your bike starts pinging as it did last time do as I suggest. If the pinging goes away just ride like that every time! If it doesn't you could try a higher octane gas, which should also cure the problem.
If you keep having problems, get someone to check your bike over. Something may be out of adjustment.
I live in the UK and use 95 octane. I don't know how that compares with your gas in the US, but 91 sounds low! It is worth trying something better, at least for a tankful or two, to see if the pinging is stopped.
You have 95 Octane available in the UK? Kewl. I don't think I've seen that high of an octane rating since Sunoco 260 went out of style. Maybe AvGas, but I ain't puttin' that in my Harley.
If you did let your bike sit for several weeks and then took it out, I'd put money (or even something of more value like -- Beer) on it being the gas.
Fill 'er up with some quality fuel and drive it.
the hill wasnt a tall incline just a steady up, and ive gone up that how many times, and i was in 6th gear and never had issue like that, ive gone up steeper than this one in 6th, and never had an issue, i just roll back the throttle and up she goes, but this time it had to put up a fight......as for fuel its about two weeks old, the bikes been in a shop for vibration problems which i fixed and runs great.
