Leaking Forks - HELP Please...
Hi All,
I am in a bit of a predicament here and not sure what to do.
I've just powdered fork lowers on my 08 Street Bob.
Just to be on a safe side, I've changed the fork seals when assembling forks back. I've followed the instructions outlined in a service manual precisely. I've used a little bit of grease on fork seals prior to driving them in. Also they did go in rally easy.
Now, I took my bike for it's first run and the oil is "spraying" out of fork seals. I am stunned. I have no idea what I've done wrong!!!
All seems to be assembled OK but the oil is leaking.
Any ideas? Any pitfalls that I might have overlooked?
Any advice would be much appreciated. I am going to pull forks apart again tonight, but what do I look for?
Thanks
Thanks
If they went in REALLY easy, something probably wasn't right. I lubed the one I just replaced really well and it was still a b@#$% to get it seated all the way in. I'd suggest pulling the lowers back off (you can save and re-use the fork oil if you catch it cleanly) and reassembling carefully making sure everything is in the right order and right side up. I recently had to change one of mine that was spraying fluid and started second guessing if I had the old one in "right side up" from the last time. But, with the help of this forum, I made sure and so far, so good.
+1 on the seal being upside down. I changed my forks a while back (going with the chromed ones) and had the same problem on one of my forks. I got some high dollar seals (good to 2,000 psi or something like that) and when I took the old ones off I noticed that one was "different" than the other. Turns out one was upside down. Maybe you beat the odds and put BOTH of them upside down. Also, it takes a while for the seals to seal real well, at least mine did.
