Finally completed project APE
Wow. They do look great but a little big for our comfort style. My husband has been talking about mini apes for a long while for his 2010 wg but is so far afraid to take on the wiring job himself. Also seems to be EXTREMELY expensive to do the internal wiring.
Can you give us details on what you had to do to wire those up? Nice to hear you're not a mechanic either. Gives me hope.
We were told by dealer they wanted $970 to do the job and that they would need to relocate turn signals to save on wire. Am hoping to pick up the pieces here and there and then find a friend, buy him some beer, and hope for a miracle.
It is real easy to relocate the turn signals. If your hubby has any mechanical ability he should be fine as long as he takes his time and documents how all the wire are. One easy way it is to take pictures.
If you are going with mini apes (10" like the earlier FXDWG's) then you should not need any more wire as there is plenty stuffed in the neck of the bike.
Also it would be a good time to switch to chrome controls. This way you could wire them while sitting at the dinner table. That is the way I will be going from mini apes to 14" apes. New controls and switches on new bars. Hardest part will be changing out the brake and clutch cable.
I sure hope you're right. Of course, I guess we could just start pulling and see what we come up with.
As for the turnsignal relocate, that should be a snaap. Dealer recommanded that as a way to save on extra wire - just move them down.
Okay, here's the sweet deal on the wiring. All I did was remove the pins from the connectors to pull thru the bars, then put back in place. No extension at all, those are stock wires. There should be more than enough for your 10" apes. Just make sure you mark the location of pins in the connector before you remove them. :-) As you see, I didn't relocate the signals. I like them on the bar a lot better than the relocation options they have.
I purchased my setup from www.hillcountrycustomcycles.com and all the wires were already ran through the bars and the switches mounted in the switch housings. There was actually very little for me to have to do.
