WG triple tree on an FXDC...suggestions?
Its not as easy as just changing triple trees. There are two ways to go about this.
If using your stock wheel, you will need:
If you are going to a WG front wheel, you will need:
The install of either of the above is not bad, but a manual is highly recommended.
Look at Accutronix for trees and conversion kits. Their stuff is pricey, but top notch.
Such for threads by WS6 Formula, ghosterider69, and me for more info.
