Feedback on High Output Headlamp Bulb
RE: Feedback on High Output Headlamp Bulb
My experience with these type of bulbs (on my car) was that it produced a whiter and brighter light ONLY when looking at the headlight, but did not produce a brighter light path, so I went with a aftermarket HID system on my car. That in mind, I would not waste my money on this bulb. Just my .02 cents.
Did you try adjusting your headlight?
A lot of em are pointing far too low.
You could use a Silverstar or something, but it doesn't really light better, it just seems like it does because its whiter than standard bulbs.
Kuryakyn has a plug in HID kit that is self contained. It runs $529 though. Clicky Here
Be careful of putting in higher wattage bulbs because they can melt your harness, especially the plug on the lamp.
ORIGINAL: Rhubarb
I put a PIAA in mine a couple of weeks ago... It would probaly make a difference, if I got rid of that damn diffuser in the light... All I get is a big halo around the sides, front isn't that much brighter.. Has anyone cut the diffuser out..? I haven't cut mine because, I think it acts as a heat shield...
Try contacting Daniel Stern Lighting for a better bulb/reflector combination. A good bulb is of little use if it is placed in a reflector that can't take full advantage of it. Change over to a better reflector and you'll see a huge improvement and not have to worry about too much heat, fried wiring, etc.
