Dealer said 09-10 Dyna bad vibration normal
I need to find out if this is true.
I just got off the phone with the service manager to set up my 1000 mile service. I told him my new 10 FXDC motor seems to vibrate a lot when I get up to about 3900 rpm. [I did the shim thing it didn't help] He said he has got a lot of complaints on some of the 09-10 Dyna on to much vibration. He said one guy told him on his 10 WG it's so bad his hands go numb. He thinks HD may be using a stiffer rubber in the motor mounts on the new Dyna's, so there isn't much he can do about it until HD addresses what ever the problem is. So other words he is telling me I'm stuck.
How many of you 09-10 Dyna owners are having what you feel is to much motor vibration ?
If they actually did change the rubber compound of the motor mounts to a harder [denser] type rubber this certainly could cause more vibes to be xmitted to the handle bars and foot pegs. I own a 2008 superglide and have had zero vibration issues with it for 17000 miles.I have been very careful not to drip oil on the front mount during oil changes, which i think has helped my isolators stay intact.When mine do require replacement i hope i can find ones made of the same rubber compound as the stock ones i currently have.Good luck resolving your problem,and please keep us informed.Note,most do not run around at 4k plus Rpms.
joesride,quote
I don't ride my bike at 4000 rpm, I'm talking about the shift point under harder acceleration. He also told me today that with 870 miles I'm safe to run it well over 4000 rpm now, just to a shift point, but keep it under red-line, if I want to have a little fun with it. This Sunday I will. I believe red-line is around 5200 so I will keep her under 4900 rpm when I shift, just to have a little fun. What bothers me is when I get up to 3900 rpm the motor starts to vibrate and it feels like it increases as the rpm go up so I haven't went much above that. Now that I have the service managers permission to run it up...I will.
I first rap a rag around the isolater, then i have a clear piece of plastic that i roll into a cone and slide it up over the oil filter and push it snug against the housing, then i unscrew the filter and let the oil run down the plastic into a oil pan....My bike is jacked up all the way on my J&S jack when i do this.If any oil makes it onto the isolator i take an airpressure nozzle hooked up to my air compressor and blow it off using 100psi..I have had no issues doing it this way.Some folks use a plastic soda bottle to do this.
