Stripped the stud in the header that holds the exhaust on....
#31
The only reason you should be concerned is if you (probably) rush yourself trying to install a new exhaust system and end up cross threading the flange nuts. No offense to the OP.
On the other hand, would you really WANT the studs to come out easy? I mean they are a fairly important part of the package.
I wonder about the stud being locked in place like that though. Let's just say I don't believe the MC does its job all the time. My bike came without nuts on the rear head pipe when I picked it up. Who knows what else they forgot (a little anti-seize maybe? )
#33
Which is a another good reason to use never-seize on your spark plugs. Steel plug + aluminum head = Potential problems. On plugs, just don't get carried away with it. The electrode and/or anode on plugs don't get along too well with never seize if it gets on either.
#34
#35
get a 5/16" stud remover or 8mm, same thing. put it on and remove it with a wratchet. do it the right way. Why take a chance of breaking it off in the head and then having to remove the head and take it to a machine shop where they will nail you again. You can buy the whole set for under 100.00. I saw the one with the picture but they make one that has internal self adjusting teeth so as you twist it it gets tighter on the material, just unbolt the stud then replace it and you can use it to re-install the new one. You've got way too much invested to do it half assed. I guess I'm just an old die hard but with 100k+ worth of tools I just reach into my tool box and get what I need to do it right the first time. Don't get mad at me, I'm just trying to help-----jack
