Scavenger Oil Change on a Street Bob
@davidnewtonparr - I'm guessing that you would have to. Anything that impedes you from removing the filler neck is going to give you problems with this setup. Let's put it this way, if you have problems removing your oil dipstick without burning your fingers on the pipes....or if you can't remove your filler neck with a 4" allen key, you will have to remove your rear pipe (or both pipes if it's a 2 into 1).
What? How often are you changing your oil? Seriously. I am going to be doing oil changes for my friends on their bikes, so I'll let you know if anything like this occurs, but seriously....I do not think that the threads will wear down anytime soon. That's like saying, your threads in your oil pan are going to wear out because you have a steel drain plug and an aluminum pan. I mean...come on.
Don't forget it's a Harley !
You said not me ,don't take it personal not everybody is going to agree with ones information/suggestions or feedback on the forum.
I guess that you did not read the ones that i have which are thousands since i joined , i have seen many feedbacks , criticism , etc., sorry i can't please everybody and agree with everything I read on here , do you ? Besides your off topic now it's all about the Scavenger oil change kit !
