Has anyone modified HD Saddlebags to quicker release?
I have the HD saddlebags that bolt on to the bike through the quick release docking hardware for my sissy bar. I was thinking of mounting longer bolts from the inside of the fender out and putting a thin nut on to hold the sissybar docking bobbins in place. This would allow me to slide the saddlebags on to the end of the threaded bolts and two locking nuts inside the saddlebags. Not quick release but at least they can be removed without having to remove the docking bobbins each time. I could then put a nice dome nut on the end of the bolts for when the saddlebags are removed. Or is there a better solution other than fitting easy type brackets? I suppose I could even use some form of wing nuts inside the saddlebags. Anyone got any picture alternatives??
Mermoto
FatBob Pilot
Mermoto
FatBob Pilot
Here you go....
Going to get to a set of these for my bags.....
http://www.phatperformanceparts.com/...bare-backs.htm
Cycle Visions BareBacks Quick Release Saddlebag System
Allow instant removal of your OEM H.D. saddlebag supports in seconds
Remove both the saddlebags and the steel mounting bracket
FLSTC/FLSTS applications are for OEM saddlebags
Dyna Glide models, FXST and FLSTF applications are for OEM accessory saddlebags
All components are made from high-quality 303 stainless steel
Chrome-plated Bare Back caps cover male end of snap when you take off saddlebags; sold separately
