Wideglide rear fender on a superglide
Old 05-03-2010 | 08:13 PM
Gladiator72's Avatar
Gladiator72
Default Wideglide rear fender on a superglide
I have a rear fender off a 01 WG,, will it fit a 03 SG? I am assuming I would need the fender struts off a WG.. But not sure.. And if so is there anything else I need to know..wiring and such...? Thanks all..
Old 05-04-2010 | 12:28 AM
fixxr's Avatar
fixxr
The 03 fender is7 3/4" wide the 01 is not as wide! You can use it but you will have to make spacers to fill the gap and your rear tire may rub the fender bolts!! most 01's run a 130 rear tire to fit that fender.
J57little
07-12-2019 07:47 PM
Robtarra39
10-24-2012 09:18 PM
dclements0
12-27-2011 12:27 PM
strongwood
06-12-2011 11:18 PM
06STRD
04-14-2011 07:43 AM
Quick Reply: Wideglide rear fender on a superglide
