Found a broken screw. is this a problem?
04-29-2010, 03:13 PM
04-29-2010, 03:18 PM
Is that the front tank mount?
04-29-2010, 03:20 PM
it is on the other side-
04-29-2010, 03:26 PM
R u talking about the bolt on the upper triple tree? if so is not just a pinch bolt that the upper tree itself is threaded on that side so the bolt should not go all the way through.
04-29-2010, 03:27 PM
K so im missing the one side...... is that a problem
Im looking for my parts catalog.
04-29-2010, 03:31 PM
No need to panic, Fred!
This bolt is p/n 4352 and called: SCREW, 3/8-16 X 1-1/2 Torx (self-tapping) (Grade 8 steel).
The bolt used on my FXD2003 looks the same and is mounted in a similar way as shown in your image.
04-29-2010, 03:34 PM
Careful your little spider friend might be hiding in that hole just waiting for you to get just a *little* closer......
04-29-2010, 03:45 PM
VazquezFXDP
10-28-2018 09:05 AM
WyJax
General Topics/Tech Tips
02-26-2017 10:07 PM
DYNARYDER87
05-07-2016 02:30 PM
PhantomMaxx
05-19-2015 12:38 PM
nujohn
11-30-2007 11:00 PM
