Yes another Ape Hanger Cable Question
Old 04-29-2010 | 04:52 PM
Sixty-Sicks's Avatar
Sixty-Sicks
plus six from drag specialties worked for my throttle cables, 50" on my brake line, my clutch was +six as well, but is extremely tight, almost to the point of not working, go at least +8 on the clutch...........I did 16" narrow glide apes on 2 inch risers on an 05 fxdc.
Old 04-30-2010 | 12:13 PM
HATZO1's Avatar
HATZO1
Yea I'll be double checking my lenghts b4 the install.
Old 04-30-2010 | 12:26 PM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by jss1975snow
For 16" Burly's narrows I used 74" Clutch cable, 54" Brake line, 39.5" throttle and Idle purchased from Hill Country Customs. Namz 8" Wire extension kit. It was not too hard, just time consuming, remove the tank and it will make it alot easier, SC Longhair has a video showing you how to take apart the wire connectors, I also did the turn signal relocation kit for my street bob.
Dude, removing the tank is a completely unnecessary step. At best, all you had to do was raise the front of it. If you have/had a 2" tank lift installed already that would have been a non-issue.
Old 04-30-2010 | 08:56 PM
jss1975snow's Avatar
jss1975snow
I tried sliding the tank back but standing on the left side I didn't realize I was scratching the front head cover with the right stock hose clamp on the fuel crossover so I would recommend wrapping that with duct tape before sliding the tank back. It just made it alot easier to remove the tank so I was'nt banging the tank the whole time I was working the cables and made it easier running the new throttle and idle. Removing the tank was a fairly easy task after I read the service manual.
Old 05-03-2010 | 04:25 PM
HATZO1's Avatar
HATZO1
Well I wanted to try to go threw HCC however I have not gotten any reply back in like 4 days via email and cant even get a phone call back or anyone to answer. So I checked out and called Magnum Shielding and really like there stuff. So Im ordering this up. From my measurements it appears correct so we shall see. http://www.magnumshielding.com/
54" Chromite II DOT Custom Brake (36454)
Length: 54"
End 1 Fittings: 180° 7/16"
End 2 Fittings: 90° 3/8"/10mm
Color: Sterling Chromite II
Chromite II Clutch Cable Alt Length (322016HE)
Travel Length: 3 1/8"
Style: Two Piece
B Cable Length: 31"
Total Length: 75 11/16"
Chromite II Throttle Cable Alt Length (33198)
Housing Length: 40 1/2"
Travel Length: 5"
Tube Bend: 90°
End Style: SMOOTH
Chromite II Idle Cable Alt Length (34198)
Housing Length: 39 7/8"
Travel Length: 4 3/4"
Tube Bend: 90°
End Style: SMOOTH
desertroamer
06-27-2012 02:39 PM
lukemc7
04-01-2011 10:41 PM
leukus
06-02-2010 06:40 PM
jkoj
10-28-2008 09:34 PM
tattoo13
05-18-2008 03:11 PM
