sears jack on 2006 dyna wide glide
RE: sears jack on 2006 dyna wide glide
I have the 50190 bike jack and it works fine on my 06 super glide. There is a ear that comes down on the right side of the frame to protect the pan, and the left side sits on the kickstand, and it clears the pan by a knats a$$, and the front is on straight frame. The only problem i have its that the jack is the same height as my bike and i have to slide it under in between the front wheel and frame and pull up on the bars while walking the bike on. Once on there i ALWAYS put a ratchetting strap (comes with jack) through the motor fastened to both sides of the jack to make sure it stays on there.
muderator
ORIGINAL: jimw411
mud
Sears used to sell 2 different jacks. The older one (which I have) is black and red. The newer ones I think are silver and yellow, though I'm not sure what the big difference is. It works good on my '04 FXD, but it is too high for sliding under the bike. Ride up on a 2x12 and get the HD frame adapters and you'll be good to go. For $69.99, it's hard to go wrong. they're made in the "Far East" like everything else, but they do seem to be well made for home use.
