O2 Sensors
Old 04-24-2010 | 11:28 AM
seawoo's Avatar
seawoo
Default O2 Sensors
Question: After you perform a stage 1 (PCV in this case). Is it normal practice OR a big fat NO NO to remove the O2 Senors from the pipes and replace them with bung plugs? In North Carolina we do not have emmisions inspection on motorcycles, at least they did not do one on mine.
Old 04-24-2010 | 11:50 AM
Foodog's Avatar
Foodog
When I installed my PC-V I just left the O-2 sensors installed and used the supplied plugs to cap off the ECM connections. Instructions say you can remove them and install plugs but that seemed like unnecessary work for me.
Old 04-24-2010 | 11:59 AM
bberck's Avatar
bberck
Ya If running a PCV with the O2 elimators you can remove them. I dont have them in mine.
Old 04-24-2010 | 12:14 PM
thedonthere's Avatar
thedonthere
Leave them in. If you ever go with the auto tune with the PCV you'll need them.
Old 04-24-2010 | 01:03 PM
dope_man_21's Avatar
dope_man_21
Check out
http://www.nightrider.com/biketech/hd2007HD_heat_00.htm.
I built a jumper for mine before any upgrades were preformed and all it required was the plugs from two sensors, two 330 ohm resistors, and some heat shrink. I soldered the resistors in to the remaining wire from the plugs and attached it to the plugs on the bike.
Old 04-24-2010 | 01:31 PM
bberck's Avatar
bberck
The auto tune comes with wideband O2 sensors doesnt it.
Old 04-24-2010 | 07:58 PM
cactusred's Avatar
cactusred
Yep, just more work taking em out, and they aren't gonna hurt anything just hanging out for the ride, disconnected.
Brunster11
03-29-2015 12:17 PM
cursedspirit
04-16-2012 07:12 PM
All Aces
21
07-21-2010 02:08 PM
SixSixRider
09-18-2009 09:41 PM
Mike5959
01-05-2009 11:11 AM
