intermitent stalling 06 dyna
Old 04-23-2010, 03:19 PM
06 Dyna's Avatar
06 Dyna
06 Dyna is offline
Stage I
Default intermitent stalling 06 dyna
Any thoughts on my 06 dyna wide glide. It runs fine but has intermitent stalling. When it stalls I am always moving, bike will re-fire. The last time it happend had to idle home
Old 04-23-2010, 04:06 PM
slojimbo's Avatar
slojimbo
slojimbo is offline
Default Stalling 06 Dyna
It's a long shot but if your turn signal security module thinks the bike is tipping it will kill power and restart. If you don't fing any other cause it might be worth looking at. Good luck.
slojjimbo
Old 04-23-2010, 04:23 PM
alysonowner's Avatar
alysonowner
alysonowner is offline
Take a 12 inch screw driver and tighten the living He** out of the battery terminals. Had the same thing happen on my 07 wg. Took it to the shop and that was all that was wrong. If the terminals are lose and the computer senses a power surge it will shut the whole thing down. Hope that works for you.
Old 04-23-2010, 08:37 PM
HD4DP's Avatar
HD4DP
HD4DP is offline
loose battery terminal.
Old 04-23-2010, 10:07 PM
gene2006's Avatar
gene2006
gene2006 is offline
2nd Gear
Check the ground cable. I cleaned both end and made sure they were tight. Runs fine now.
Old 04-25-2010, 02:17 PM
sniper77's Avatar
sniper77
sniper77 is offline
A 10mm wrench will tighten those battery connections much more securely than a screwdriver.
an ounce of prevention.....................
Old 04-25-2010, 06:16 PM
man4mopar's Avatar
man4mopar
man4mopar is offline
Check this out, may just be your problem.
https://www.hdforums.com/forum/dyna-...you-later.html
Old 04-25-2010, 06:55 PM
tully_mars's Avatar
tully_mars
tully_mars is offline
Hope nobody is offended by this, but a 10mm? I thought this was a US made a bike, displacement measured in inches! I hate to see us falling to the metrics.
Nothing is more frustrating than to be working on my HD or Ford and have to put a side my normal wrenches when that odd metric bolt shows up.
Sorry, the irony just caught me.
Old 04-25-2010, 07:42 PM
HOGRIDA_06's Avatar
HOGRIDA_06
HOGRIDA_06 is offline
Try not to get to upset, but your whole front end is metric and made in Japan.
Old 04-25-2010, 09:31 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
I do believe there is one of every type and size fastner known to man on my Dyna.
Quick Reply: intermitent stalling 06 dyna
