I thought this was interesting...
Old 04-20-2010, 07:56 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Why must they use fear, coupled with someone's ignorance to keep customers. Sounds a little like gustapo-tactics.
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Originally Posted by domenicp7
Featured Tuner in major Bike Magazine. Ed at Dyno Difference.
That is what the warning really is all about. IMO. Once you alter the enigne dynamics you have to have it tuned by someone who know WTF they are doing.
Old 04-20-2010, 10:58 AM
jstreet0204's Avatar
jstreet0204
jstreet0204 is offline
Here they are talking about components that the calculations that the ECU does to determine fuel and timing are directly based on. When done correctly a change in cams means a change in injector timing. Load calculations are based on displacement, and if you starting uping compression, you can't run as much timing. I'm pretty sure these kits come with a base map for the known components. All it means is that the tune needs to be adjusted if you start changing these components. This is a big difference than the ECU compensating for a little extra air flow from pipes or an intake, which is more than likely what your dealer was refering to.
Old 04-20-2010, 11:52 AM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
Aside from performance considerations such as jstreet mentions, the cautions probably reflect a good bit of corporate CYA and/or EPA BS ... probably part of what's kept them in business as long as they have been ....
Kind of like all those "may cause serious injury or death" warnings you see on just about every page of the service manual ....
R/
'Chop
Old 04-20-2010, 02:53 PM
tscreener's Avatar
tscreener
tscreener is offline
I dont believe anything that any dealership says, I was a mechanic for 12 years and I have heard the service managers say some unbeleivable things over the years.
Old 04-20-2010, 04:27 PM
editbrain's Avatar
editbrain
editbrain is offline
Well what I was told is that the EFI can adjust up to 14% by calculating A/F. That is what I was referring too. Now here on the Harley site it says it doesn't.
Old 04-20-2010, 06:52 PM
jstreet0204
Which is probably about right. The components listed in that warning are all things that the computer needs hard coded values for and can't be adjusted for.
Old 04-20-2010, 09:11 PM
thedonthere's Avatar
thedonthere
thedonthere is offline
Explain underpowered, and the kits only $599.00 from HD of Chicago.
I just bought a "kit" from a local indy type guy for $519.00. That included a complete gasket set with .030" cometic head gaskets,Axtel pistons fit to my cylinders at .002" and my rings gapped and installed on my pistons.
Cascade
Engine Mechanical Topics
20
02-15-2016 05:26 PM
Ink83
09-04-2015 10:27 PM
Morloka
05-13-2008 05:18 PM
6165hd
03-08-2008 01:34 AM
berryw
Exhaust System Topics
10-08-2005 12:31 AM
Quick Reply: I thought this was interesting...
