An old question: Tuner or No Tuner
1 Post
Get a copy of the Fall 2006 Enthusiast Magazine published by Harley-Davidson. H-D states in an article in this magazine that the Dephi equipped closed loop ECM bikes to not need remapping with exhaust and air cleaner upgrades.
However since I put the TMax (and new air filter) in, the bike runs much, much better. It idles smoother, it sounds better, and it pops much less on decel. I also think (but have no proof) that it's running cooler.
CAUTION: Harley-Davidson EFI systems will not compensate for any component changes. Do not mill heads or increase compression in any way. Do not use cams other than those supplied in the kit. Do not change kit components. Failure to comply may result in engine damage. Dealer installation required - failure to comply may result in a lean fuel condition and severe engine damage.
1 Post
My '06 Dyna with V&H slipons did not need a tuner. It ran, and I think it obviously ran fine for the first owner, as he put 18k miles on it like that. I will agree that a tuner was not -needed-.
I'm sure it ran cooler, before I installed them it would high idle when sitting in traffic, after I put them on it didn't do it once in a year of riding.
