Street Legal or Pro Race 103" Kits - why the power difference?
I ordered an SE Pro Super Tuner and a 29893-07A SE PRO 103" ST2 RACE KIT for my new WG which I collected on Friday. However, I've just noticed the Invoice states they supplied and fitted the 27566-09 103" ST2 50 STATE KIT. I believe (but I'm not sure) that both these kits use the same engine internals but the 50 State Kit is Street Legal and is supplied with an SE air filter and backplate. This is odd as I supplied the dealer with my existing SE filter and backplate.
However, look at the power/torque output difference between each kit.
Are they each using a different tune via the SE Pro Super Tuner? What else is different about these kits?
I could use some advice here before I go back to the dealer with this issue.
I think the only real difference between the two is the standard 103" kit comes with a stage 1 a/c and slip-ons, while the race kit doesn't. I would guess with the #'s being a little higher with race kit compared to the standard would be because they used the heavy breather along with a performance exhaust. Did you already have this kit installed? If not spend a couple hundred more and get your heads reworked. It will really make a huge improvement.
