Shorter Shocks with 18" rear wheel
I am 5'9" and on my 2009 FXDB I installed some Hogpro Daytona's. The rear is an 18" wheel since they dont make a 17" like what comes stock and the tire is a 180. These wheels made my bike just a tad bit too tall for me to touch the ground comfortably.
Can I run shorter shocks without any interference from the rear tire and wheel being larger than stock?
Thanks for the help.
This is one instance where you should avoid using lowering blocks as an option. I recommend 11.6" works performance shocks or Ohlins. Made for your weight and riding style, they won't be easy to bottom out, ride like a dream, and lower the bike about 3/4" in the rear. I think you will be fine with the lower suspension and slightly taller tire wheel combo. May have issues with lowering blocks, cause they lower the bike without reducing the suspension travel.
joelsuff
04-01-2015 04:50 PM
