**Screaming Eagle Compensator**
Old 01-27-2011 | 11:09 AM
Bertk's Avatar
Bertk
Hello,
I have just installed the SE Compensator on my 08 SG. In step 8 of the instruction I should be able to rotate the comp sprocket by hand. The sprocket will not rotate by hand. All the springs look like they are in place and so does the Thrust Washer. Has anyone else run onto this?
Step 8:
Rotate the compensating sprocket (4) to make sure there
is a light pressure on the sprocket from the springs. No
clearance should be felt. A slight rotation should be possible by hand with the transmission in neutral.
Old 01-27-2011 | 12:30 PM
atrox88's Avatar
atrox88
Thanks for the great write up
Old 01-27-2011 | 12:53 PM
kerry_okie's Avatar
kerry_okie
I did the SE Comp when I installed an Andrews 30T sprocket ('07 FXDB). Of the things I've done to the bike so far, I rate these two parts as the best bang for the buck.
Old 02-01-2011 | 11:49 AM
renlan's Avatar
renlan
So anyone try just loosening the inner primary bolts a bit to get the rotor off/on instead of grinding. Then just torq them back down, or is that instant death to the inner primary gasket????????
Old 03-30-2012 | 01:18 PM
WS6 Formula's Avatar
WS6 Formula
Below prices today 03/30/2012 from:
Lake Shore Harley-Davidson / Buell - Libertyville, IL
http://www.lshd1.com/servlet/StoreFront
FREE SHIPPING $500 IN MERCHANDISE AND OVER
Orders Sent Via UPS
Through 3-31-2012
(Offer US 48 States Only - NOT HI, AK, PR or APO/AEO/FPO)
Quantity
Part Number
Description
Price
40274-08A
KIT-COMPENSATOR,DYNA/SFTL/TOURING Screamin Eagle (rotor & bolt included)
$199.96
STATOR ASSY, 40 AMP, 3 PHASE (larger then 2006, fits 2007 and up as well as above rotor)
$113.60
39929-06B
CHAIN TENSIONER ASSY (upgraded part)
$74.52
SCREW, CAP TORX, STATOR
@ $1.20ea = $4.80
GASKET, PRIMARY COVER
$24.32
GASKET, TOWER
$0.80
40274-08A
39929-06B
(top one)
Originally Posted by mud
Old 03-30-2012 | 02:44 PM
drspencer's Avatar
drspencer
Originally Posted by Bertk
Hello,
Step 8:
Just did this mod, couldn't rotate mine by hand either.
Old 03-30-2012 | 02:46 PM
drspencer's Avatar
drspencer
Just did SE comp & 30T pulley to my 07 FXSTC.
During the whole operation, I couldn't help thinking that it seems like it would be easier to just remove the inner primary, rather than go through the grinding.
Old 06-28-2012 | 05:40 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Tagged for reference.
Old 06-28-2012 | 09:32 AM
Mean Gene's Avatar
Mean Gene
Great Job on write up! I did mine on an 2008 Electra Glide Ultra Classic, because of dealer breaking a tooth off. I won't mentioned the dealers name, but I am skeptable of most. I should have installed the improved tensioner, apart we go again!
Old 07-06-2012 | 10:23 AM
rare100thHD's Avatar
rare100thHD
Improved tensioner needed here too! And Apart we go again, Chattering Chattering Chattering at steady crusing speeds after 25 miles When parts are all heated and swelled up. May also try to add a few holes somewhere to aid lubrication of the moving sliding cam on the shaft splines!
Quick Reply: **Screaming Eagle Compensator**
