new speedo/tach ONLY 2009 and up??
Indicator Lights
Follow up to the individual speedo / tach. I ordered the Lowrider handle bar clamp, which is where the indicator lights are located on the lowrider. However, I'm not sure if it will clamp on to my bars with the built in risers. If it doesn't work - I think I'll try the LED dash bolt and maybe just go with a Neutral / Oil Light. As someone else mentioned I can see the turn sigs on the handle bars and I also know if I have the high beams on.
