Question for Windvest owners???
2007fxdc, I'm curious to know the model/size of the Windvest as well as your handlebar rise-8", 10", etc. Thanks, Fred
Been running mine since last fall and no issues. My mounts go on the risers (will try to post some pix below to illustrate). The clamps with mine are too big for the risers but 1/4" but I knew that when I bought it from forum member bberck. That was fine with me because I didn't really want metal against metal attached to something that would be getting buffeted and vibrated by the wind. bberck had some raw rubber strips that he had used to take up the extra space. I expanded on that and went to the hardware store and got some rubber rings that were the same inside diamater as my risers and a 1/8" thickness (1/8 + 1/8 = 1/4"). These rings were not rounded but, rather, they were flat around the circumferences and the top and bottom edges. I used some super glue and stacked two together for each riser and took a razor blade and cut a slit to get them around the risers. Then I attached the clamps over the rubber rings. Looks good, protects my chrome risers, and works perfectly. I periodically check all the mounting bolts on my windvest and they seem to be staying tight just fine. I'm super happy with it!
Good luck,
Mike
http://www.wind-vest.com/harley/dyna_lowrider.htm
I'm sorry Mike, Here's the link where I found the Windvest shield for the 09 Lowrider. Thanks again for all the post, Ron
Looks like they have more than one website.
http://www.windvest.com/
Mike
I had a QD shield before and almost never used it because it was f'ugly and bulky and I just didn't like it. It worked but I always looked for reasons not to use it. So I took a chance on the WV just to try it. I immediately sold the QD shield and haven't looked back. The WV is smaller and more suited to a dyna, in my opinion, and if you have the room and/or the ingenuity to get it adjusted right, it works very well for its size.
All that said, I'm still not a windshield guy. When the weather finally settles on staying warm, I'll take it off and not put it back on again for the summer except, maybe, if going on a long road trip somewhere and then it will be more of a bug collector than anything else.
