???? For those with Ricor Suspension
I am ready to upgrade my suspension. How are the Intiminators working out? What about the rear shocks.?Any new installs? I checked the ricorshock.com site and the front inserts are $300 and the shocks are $630. Are there any discounts now for site members?
I have the intiminators and think they are really worth the money, no more brake dive or tacking grooves in the road. I have the progressive 440's and while better than stock I don't think they are worth the money. They are too harsh even on the softest setting when I ride solo, I'm 185 lbs, now when I'm loaded up for a trip the shocks are fine. Thinking about getting the Ricor rear shocks now.
I just went through the suspension phase this Fall/Winter. By far the mod that made the biggest difference was the True-Track. After that it would be the Intiminators and the Ohlins Shocks with a tie, and lastly with very little if any improvement was the Superbrace fork brace.
To be fair, to the Intiminators and Ohlins, I would have to have put them on first, because they have each been reported to do much of the same work. So it could be that the main reason the True-Track made the biggest difference was because it went on first - who knows.
Steve
Steve
I can say beyond doubt that Ohlins are an incredible experience. Someday, I should get a pair of Ricor shocks to test against the Ohlins(hopefully been waiting 2 months now) and will be able to give a comparison. Can't comment on intiminators, although it does seem the newness of them has worn off and I have been seeing a lot of additional mods going into the front ends to improve upon intiminator owners throughout the forums. I can't see how dropping them in can correct improper sag and spring rates for a riders weight. I don't think I have seen too many trying to continually improve racetech springs and emulators(they make their springs in many variations to match rider weight).
Quite a comment after saying you "can't comment on Intiminators"
I don't believe we ever said Intiminators will correct improper sag or an incorrect spring rate. We have always said if you are happy/satisfied with your current springs there is no need to change them when you add the Intiminators. While some have changed their springs at the same time they installed the IAS valves, as they have their forks opened up for the install, the majority have not, and the ride reports both on this and other forums have remained very positive overall.
I will check with Brian and see where we are at on the proto-types we spoke about you testing for us and PM you as soon as I find out.
Hal
Rounder
Hal
Hal
I have the ricor intiminators, a superbrace, progressive drop ins, true track and running amsoil 10w shock therapy. Here's what I can say, I don't think any one item necessarily makes or brakes the suspension, it's a combination of how things are affected by other components on the dyna frame. Me personally, I started with amsoil 10w, made a difference, then to progressive springs, made some difference, then ricor intiminators, big difference, then finished up with true track and superbrace, big difference again.
All these differences were effective for various parts of "the ride", some for potholes, crappy rodes, braking, nose diving, and others for cruising, turning, etc.
I am finally at peace with my front end now, and have actually realized how much my rear shocks could use some attention since the front is overhauled. I was this close to ordering the new Ricor rear shocks, I like the look and I have the confidence in their product to put em on my rear end, however, I feel the next big piece needing attention was my stock exhaust, can't afford to do exhaust and those ricor rear shocks currently, but that will finish my suspension when I add the ricors to the rear.
Just my .02c
Just my .02c
Thanks for the replies. Intiminators seem to be doing as advertised. Has Ricor started sending out production shocks yet? Any reports on them? Any Forum discounts offered?
Anyone have experience with Hagon shocks or shocks other than Ohlins? What about Progressive 418s as a lower cost but good shock?
