tank badge
Old 04-08-2010, 03:08 PM
leggz's Avatar
leggz
leggz is offline
Stage III
Default tank badge
whats the best way to remove tank badges,i have black denim paint does that matter? will there be glue residue
Old 04-08-2010, 03:56 PM
rounder's Avatar
rounder
rounder is offline
heat gun.
Old 04-08-2010, 04:48 PM
trip20's Avatar
trip20
trip20 is offline
I'd suggest a hair dryer since it doesn't get as hot as a heat gut but the heat gun will work too if you're careful.
To remove residue use wd-40
Old 04-08-2010, 05:37 PM
sanlyn's Avatar
sanlyn
sanlyn is offline
+1 on the hair dryer/wd-40
Old 04-08-2010, 05:55 PM
datrahan62's Avatar
datrahan62
datrahan62 is offline
if it is just the harley davidson name on denim black those are just stuck on with tape i pulled mine off and pulled tape off then just wiped tank down-- cant tell it was there
Old 04-08-2010, 06:55 PM
junior07's Avatar
junior07
junior07 is offline
i did the same thing with a red denim tank. but if you would like to save the badges i would suggest the hair dryer. when i pulled mine off, they came right of and the residue just peeled of without a mark. but the badges got bent a little when pulling them off, so i trashed them. you
Old 04-09-2010, 02:01 AM
nitebobber08's Avatar
nitebobber08
nitebobber08 is offline
hair dryer works wonders! also i would make sure and have a little bit of goo gone and some windex to clean the area after the removal.
89Speedy
08-24-2012 05:58 AM
MrPappagiorgio
08-15-2012 08:16 PM
ct555
03-28-2012 05:46 PM
yank
07-21-2009 02:21 AM
hangnman
11-03-2006 11:14 PM
Quick Reply: tank badge
