Engine light goes on for a couple seconds
Old 04-08-2010 | 07:54 AM
greg3131's Avatar
greg3131
Default Engine light goes on for a couple seconds
Fxdb with 8000 miles. Once the bike starts the engine light goes on for a few seconds then turns off. Anyone know if this indicates something?
Greg 07 fxdb
Old 04-08-2010 | 08:41 AM
shimmon's Avatar
shimmon
Im pretty sure this is normal function (just letting you know that its checking all its sensors) i think if it stays on longer than 3-4 seconds, or if it goes off then comes back on, that indicates a trouble code.
But you can always check your trouble codes to make sure everything is all good. You can search this forum for the how too and code meanings.
Old 04-08-2010 | 09:25 AM
Streets of Fire's Avatar
Streets of Fire
mine did that... turned out to be a loose battery cable.
Old 04-08-2010 | 12:43 PM
bakerm75's Avatar
bakerm75
Doesn't it come on while the engine builds oil pressure, then goes off when its up to snuff?
This sounds wierd but I had a problem with the engine light coming on caused by a loose horn cable hitting the 2nd cable. Some sort of ground I guess.
Old 04-08-2010 | 01:01 PM
Fatboy Brian's Avatar
Fatboy Brian
I think it also does that when you have a old code.
Old 04-08-2010 | 05:01 PM
NOZEM's Avatar
NOZEM
Pull the sparkplug cables clean the connectors and put back on.... that did thr trick for me.
elite51203
05-29-2023 01:18 PM
Kyle C Kirk
11-09-2015 02:13 PM
chizman
05-15-2011 04:35 PM
bakerm75
06-17-2009 01:03 PM
gatorwalt
07-24-2008 10:26 AM
Quick Reply: Engine light goes on for a couple seconds
