front end options?
front end options?
i was recently crashed on my 2010 fxd.( driver blew a stop sign.).. the repair shop insurance man estimated to replace front forks, trees, wheel and tire...
i was thinking of upgrading to a fatbob front-end, minus the headlight... im thinking that i would only have to buy a new front fender, brake caliper and rotor, master cylinder, brake line, over and above the replacement cost of the standard fxd items.
im not sure yet how much cash difference i would have to come up with, would the upgrade be worth the money?
anyone think of any other direction i might go in the mod department, that wouldnt be pricey?
The biggest pain you will face with your plan it going to be the wheel. Your FXD has a mid-glide front wheel, which will not just swap to use in the Fat Bob's wide-glide front end.
You will need to either change wheels or work out custom spacers for your stock wheel and rotor/caliper.
You can use Fat Bob triple trees, FXD tubes, and Wide Glide sliders. This will give you the same rake as your stock set-up. A new Wide Glide axle and Wide Glide front wheel will line everything up so no custom spacers are needed.
The parts for a Wide Glide front should cost about the same as the stock replacement parts. Depending on what route you take, you should not have to take much money out-of-pocket.
I think most will tell you the only benefit you will get is appearance. I have noticed no difference in handling. I do love the look of the wider stance.
Here is a FXD with a WG front end:
Dang John, I gotta start wearing patch or sunglasses looking at your bike, all that chrome sparkling makes me have to squint to look at the computer. Looking good bud, looking good.....
Spoiled bitch.
the beatings will continue until morale improves, the beatings will continue until morale improves...
