security system
security system
Ok I give up I have a 07 superglide and was playing with the security Bought this secound hand so no manual.
Any way after lots of reading I reset the pin and the tried the over ride proceedure about 20 times with the same out come four way flashers on
and thats it. If I can't get that working then can I remove the system
It's worth it to keep trying to start with the pin until you get accustomed to it. Can come in handy.
Just to make sure you are following the right procedure:
Turn IGN key to IGNITION and immediatly hold both turn switches until 5 dashes appear in odometer window.
Enter first digit of code by pressing left turn switch (x) times
Press right turn switch 1 time
Enter second digit of code by pressing left turn switch (x) times
Continue with all digits of code
I have changed pin and can get it into transport mode but no go with overide so far I will try some time between tries as this has allready cost me money ,,a taxi ride to go and pick up fob.
so If I don't get it working I will be lookin for a new TSM
Thanks to all
'10 Wide Glide
07-11-2018 09:49 AM
