I think I may be screwed!!!
I have seen bad grounds do some crazy things. I once put a battery in a Skytrak 10054. Then the outriggers wouldn't work, and all I did was replace the battery. It was the ground, even though the lift would start and operate all other options. Weird stuff.
Anyway, back to the bike. BAD GROUND SOMEWHERE.
We now have the answer !!!!
I can't begin to tell you how happy I am and how stupid this problem was. Not stupid on my part but stupid somewhere. Indy couldn't find short, I drove home with no lights or horn and made my drug induced, post surgery hubby into the garage - I know, bad girl - but this had to be fixed.
So, running lights, no brake lights, no horn and all because of a short in the actual ignition. After looking at each and every wire and connection I started doing the pissed off girl thing and pulling the key. Well, when key is moved, lights dim. There is what must be the sweet spot now. If my key is not in the exact right loction, the bike shorts out everywhere. Haven't tried it riding. Hoping vibration doesn't make key move and lights/horn to short again but since I only work 2 miles away, I'll try in in a.m. and see how it goes. Guess I now have to start my bike up early in a.m. and then **** off my neighbors some more w/ a horn beep. The lights work w/out the horn but if the horn is out, the short is back.
Will be calling dealer in a.m. to find out about warranty replacing ignition switch and also my indy and letting him know that, even though he missed this weird wiring, he didn't cause this problem either.
Thanks everyone for your help.
freebyrd
10-31-2008 09:08 PM
freebyrd
05-26-2008 02:48 PM
