Does anyone know the torque #'s on the header phlange nuts for V&H Bigshots? I torqued them to 10lbs,but they came loose after a 20 mile run. I have the SE gaskets also.
60-80ft/lbs. If you used the stock bolts. If V&H supplied new ones (?) you should check with them. The torque value is from an engineering standpoint for the bolts, not the head. That being said, if you used different bolts, you should check witht he manufacturer.
They should be torqued to 120 in lbs or 10 ft lbs. You are supposed to retorque them after the first ride or so. After re-torquing them they shouldn't loosen up again for a while. Just check them periodically.
Hmmm, they have higher torque specs for 09. anything change? This makes me wonder if one should follow the new specs for the older bikes as well and torque to 100-120 in/lbs.
