I have a question for Street Bob with forward controls
Old 04-02-2010, 12:53 PM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
Originally Posted by LeeLee
First off, thank you so much for all your help so far. So, if I have this right, I should buy the 2005 kit (p/n 49080-03a) right. Not the one for '06 and up (my bike is an '09). Do I also need to buy a longer shift rod that is for the '06s and newer? Is there pics anywhere of this install? Thanks again!
Use the 2005 kit and get the longer shift rod, if you don't use the longer shift rod then the front shift lever will hit the primary cover when you up shift. The longer shift rods in the link in my previous post come with the stronger heim joints that won't break like the originals or the ones that come in the kits. There also nicer then the cadmium plated ones in the kits.
Old 04-02-2010, 01:48 PM
jcopel's Avatar
jcopel
jcopel is offline
I did it according to WS6's instructions, part numbers and all. Super easy job - no issues at all. I've put about 1000 miles on them and love 'em.
Go for it, man. You won't be disappointed.
+1 on the comment about the nicer shifter rod - much better quality.
Old 04-02-2010, 04:28 PM
Socal Bobber's Avatar
Socal Bobber
Socal Bobber is offline
Thanks for the advice.
At first the sund of using the 2005 kit and a different rod seemed a little overwhelming, but someone else said they did it and it works great so why not give it a try.
I will let you know how it turns out.
Thanks again
Old 04-02-2010, 04:37 PM
Socal Bobber
Originally Posted by QehQeh
Make sure you go through this thread -
Anyone Run Mid Controls only? -
before you make your decision
hmmm maybe I should just put on highway pegs.
I am over 6' tall and have had some cramping on longer rides, but with about 2000 miles with mids I have gotten comfortable with the feel.
Now I am more confused
Old 04-02-2010, 04:52 PM
NOZEM's Avatar
NOZEM
NOZEM is offline
Dude, no guts no glory. this by far the easiest mod you'll do on your bike.
Old 04-02-2010, 05:00 PM
AlFoley's Avatar
AlFoley
AlFoley is offline
Well there is one simple advantage to having the dealer do the installation, mine were installed when purchased the bike and at 9600 miles started to leak from the plug on the primary cover. When I took it in for the 10K service, (had done at 9750 miles), they had to take the primary off and fix the leak and was covered under warranty as well. I am 6"2" and really appreciate the leg room.
Old 04-03-2010, 06:34 AM
jcopel's Avatar
jcopel
jcopel is offline
This is with WS6 part numbers. I just tucked the shift lever behind the engine bolt. I did hi-way pegs about a year. I like this better.....
Attached Thumbnails I have a question for Street Bob with forward controls-dscn3984.jpg   I have a question for Street Bob with forward controls-dscn3981.jpg   I have a question for Street Bob with forward controls-dscn3986.jpg
Old 04-09-2010, 10:53 AM
LeeLee's Avatar
LeeLee
LeeLee is offline
Stage IV
How come I can't find the '05 and older forward controls in black?
Old 05-30-2012, 05:13 PM
Papa Bear's Avatar
Papa Bear
Papa Bear is offline
Have I screwed up?.....
I have only just read this thread but unfortunately I have already gone ahead and bought an 06 upwards kit for my 07 FXDC. I am now a bit confused whether I have done the right thing and which transmission lever I should be using.
Could somebody please clarify for me?
Has anyone posted a "dummies guide" with photos for this mod? (I am leaning towards the hacksaw to the shaft method)
Old 05-30-2012, 06:59 PM
WS6 Formula
https://www.hdforums.com/forum/5990791-post17.html
Quick Reply: I have a question for Street Bob with forward controls
