Best wearing rear tire for an 09 Superglide
No one I've talked to here has used the Avons on a Harley although some of the
critch rocket guys really like 'em. My mech says that I'd really like the feel of the
Metzlers, but he thinks they'd wear out faster. A number of locals have switched
overt to Metzlers and really like them, but there are some early signs of fairly
rapid wear on a couple bikes.
I was getting about 7000 out of the stock tire, went to the Perelli Night Dragon at the last change, I have over 5000 miles on them, and hoping to get 5000 more, the wear looks great, and to top it off I should check my air pressure more often, but I don't, been known to ride with the front tire about 3psi light and the rear about 5psi light.
I have the night dragon on the rear, and the metzeler on the front.
Not enough mileage to comment about wear.
However, I can promise you from my experience so far, I would NOT go back to original tires ever.
These handle so much better it's unbelieveable. Way more 'sure footed' in the turns, and no tracking in grooves whatsoever.
The stock tires were crazy about tracking, and i always felt like I was scooting while turning.
My local indy's tell me the metzelers are great tires, and a lot of guys are getting between 8-12k depending on your riding style.
I have heard a lot of good about Avon's too.
You will be fine with any of these, but I wouldn't go back with stock for sure.
Good luck!
Good luck!
This tire works very well, I'll be changing later this year, but I suspect I'll get about 13-14K out of it. Only got 5500 out of the stock K591.
http://www.latus-harley-davidson.com...ll-17-Rear.htm
