FXDF buffeting cure?
But on those looong runs, windshield & bags sure make the trip more enjoyable.
And it all detach's quickly, so you can be cool when you get there..
I know, I know...... "Why didn't you just get a Bagger"
If you want to keep the short detach screen and find the lowest cost and simplest solution to cure the buffeting, it's the Laminar Lip.
Yes they helped my problem a lot! I'm like most, I dont care for windshields much.
do you need to move the stock blinkers for them to mount? curious as my quick detach i have mounts to the stock blinkers, and can't move them at all, and wondering if i can mount the fork air baffles without moving anything...
Stock blinkers are on the handlebars.
Your quick detach 'what' mounts to the stock blinkers?
Fork air baffles? are you talking about the Memphis Shades lowers.
If so they mount to the forks. not even close to my blinkers.
If your blinkers are mounted on the forks, then some of this makes sense.
yeah my 2000 dyna wide glide blinkers are mounted on the forks, and the bottom of my datachable windshield slides onto a rubber grommet that is on the blinker shaft, and the top of the windshield slides onto a rubber grommet up top and is the old style quick detach that has a spring type clip, so i couldn't remove the blinkers and move them, as my windshield would have nothing to mount to....here is a pic if you can see it
You might have a problem with the system I have... Howeve I'm sure Memphis Shades would have some kind of an option..
