Dash panel for lowrider tank?
Old 03-30-2010, 02:04 PM
icufltrn's Avatar
icufltrn
icufltrn is offline
yep that's the 1. i did find 1 sight that thought they could get it but they eventually realized it was obsolete. my dealer said they tracked 1 down but the person wouldn't part with it. the elusive 48047-95a. i can't understand why they r not easier to find considering how many bikes used that dash panel 95-03
Old 03-30-2010, 02:22 PM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
Originally Posted by icufltrn
.....i could take some pix of it. depends on the weather next couple days....
When you have the console off, could you add some dimensions to the image above?
TIA,
FXD2003Rider
Old 03-30-2010, 04:38 PM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
I swapped my '05 FXDI tank out to an '04 FXDL tank .... I used the console from an '06 FXDB and reused my speedometer (the 4" speedo from the riser works with that dash) ...
I just reused my wiring (it reached, barely) including my 'idiot' lights ... that I fabbed up a little work around for ....
I had to get a tank cover plate with the dash mounting tabs and reuse my fuel pump, etc ... but, since you have carb, that's N/A ....
I think you could still use the Street Bob console; but, if you want the switch on the console, you will either have to cut a hole and mount it (there is a thread on mounting the switch on the dash) or better yet, go with a new '10 Wide Glide console (it has the switch located on the dash) ....
I don't have the part numbers for the console I used available ... but I might be able to look them up or find them ... I just bought the parts new from Zanotti ... paid maybe $75or so for the console and parts ....
I think you should be able to figure out a solution ... using that Low Rider tank that should work out alright for ya ....
R/
'Chop
hotroddarin63
04-22-2012 04:36 PM
red_headed_stranger
03-05-2012 05:01 PM
georgeplg
05-24-2011 09:04 PM
fighthedude
04-08-2011 07:25 PM
98fxd
08-24-2005 07:58 PM
Quick Reply: Dash panel for lowrider tank?
