How to correctly adjust the rear shocks?
I adjust my rear shocks to the fronts, since the fronts are not adjustable. When I am riding and hit a dip in the road you will want your front and back to react the same. If the rear is too stiff the front will, for lack of a better term, act like a pogo stick. The rear will force more wieght transfer to the front and make it bouncy and feel a little on the uncontrolled side.
When you go over the dip in the road at a higher speed adjust the back shocks to go down at the same time as the front shocks.
It is easy to see and feel once you pay attention to what is happening. I am 200# and set my rears on #3. If my whif is with me I go to #4 on my SE FatBob.
If you think you are in between numbers on the rear then go to the softer setting for better control.
Hope this helps
Gutter man
Hope this helps
Gutter man
