Wiring tailbones converter???
Well i have been playing around with the wiring i CAN get to signals to turn on, but no blinking or brake lights....im not sure what im doing wrong
I chopped the rear tailight off and am using my signals for everything now
Therefore i have nothing to plug the stock harness into so i have to hard wire it and its not going too smooth
Has anyone ever wired up rear signals without the harness?
Do you have a module without the plugs on it?
I have my rear harness removed and just extended the taillight wires up to the module under the seat. Mine (module) has the plugs on it so I did use the plug off the factory rear harness to splice the signal wires into.
With the module in place you only need the blinker wires off the module running to the back and everything should work.
All the wires at the front of the module need to be hooked up.
My module does have plugs its all hooked up,So what your saying is use the factory plug off the rear that normally would plug into the rear tailight and splice your wires from your tailight into that and plug that in to the module?
Ya I cut the plug off the rear harness (one under the seat) and plugged it into the module and pulled the rest of of the rear harness out from under the fender and got rid of it. Then ran the turn signal wires back to the plug and soldered them on. Just needed 3 wires for my 08. They share a ground then the power for each turn signal (dont recall colors off hand but think it was brown and violet). You just need the turn signal wires here and just cap the running and brake wires. The module makes its changes before the rear harness so the signal wires are all you need.
