Dyno'd my Fatbob 113" today
Heads were originally done by Big Boyz for a 107 build but were removed and the intake exhaust valves and guides were changed. 7mm valve guides were installed
Hpi 51mm throttle body with se injector
se pistons
se 110 jugs bored to 113
woods 400 gear drive cams
se heavy breather
vh 2-1 big radius pipe
se adjustable pushrods
se roller rockers
se lifters
r and r billet cam plate(originally had a rr 615 cam in it)
10.6:1 comp ratio
Bob Woods said that the pipe is likely "holding it back" but I just lol'd at them and said man it is putting out plenty! I'm done with the motor on this thing. lol
se pistons
se heavy breather
se roller rockers
se lifters
10.6:1 comp ratio
Also, did you do anything to the bottom end?
Cool numbers Lee.
while they said it was holding it back I don't recall seeing many bikes on here with these sort of numbers. I am perfectly content loosing a few hp or ft/lbs of tq for a pipe that looks and sounds good. Matter of fact I like the pipe so much that I put the same one on my cvo springer.
yeah he split the cases welded/trued/balanced the crank with a timken conversion. Forgot to mention that. oops. lol
