Just bought a used 2006 Dyna with 3686 on the...
Old 03-20-2010 | 11:09 AM
TDSnowSPR's Avatar
TDSnowSPR
Default Just bought a used 2006 Dyna with 3686 on the...
Old 03-20-2010 | 11:16 AM
LX HEMI's Avatar
LX HEMI
first i've heard of motor/trans alignment and starter issues. my 06 Dyna Bob has 12K with no probs. I also have a jockey shift and suicide clutch.
Old 03-20-2010 | 04:28 PM
TDSnowSPR's Avatar
TDSnowSPR
LX what brand Jockey shift do you have?
Can anyone help me with the above listed issues?
Old 03-20-2010 | 06:07 PM
HDDyna2006's Avatar
HDDyna2006
Do a search " Stator" on dyna section, lots of info.
Stator screws come loose, some have tigwelded them before it happens, some have the updated part.
In my case, didn't hear noises, just ran out of battery, I guess I didn't see RED warning light at odometer while riding during day to work. MoCo cover my parts, not labor.
Old 03-20-2010 | 06:34 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Search Dyna pages (or my user page) for my thread "Finally - Good News...". Original post was May of '09; should be an easy find. All you need to know about the IPB issue.
Old 03-20-2010 | 08:07 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
First 1/2 of the 06 model year dynas had no alignment dowels in the engine cases. (mine doesn't have them as it was made in Dec 05) So if your inner primary case was put on correctly and aligned right you should be ok. If not, your inner primary beairng may crap out. The fix is a new IPB and new cases from the MoCo. There are many threads on this issue here so start searching inner primary bearing and read up.
The 2006 dyna stator is a POS with screws instead of welds. The screws can back out and toast the whole assembly. The fix is a 07 welded stator & rotor and the screaming eagle compensator as well. Not rocket science..look for the threads by Mudpuddle on this fix.
There was a recall on the neutral switch and battery box bolt so call the MoCo customer service line and give them your vin number and see if yours has been done.
There is a TSB on the steering head clunk. The fix is a heat treated hardened washer which costs like $2 and handles more torque. If your starts clunking it is an easy DIY. Otherwise just buy the washer and replace it when it is time to repack the steering head bearings.
There is a TSB on cold start surging on 8 degree fuel injectors on the 06 early models made before May 2006. The fix is replacing them with CVO 25 degree fuel injectors. Look at your injectors under your tank behind the horn with a flashlight the 25 degree ones have "25" printed on them.
You should be able to find a used service manual on ebay for $20.
Have fun with the bike...I love mine. I have had the recalls done and the 8 degree fuel injectors swapped out for 25's. No IPB issues or stator issues yet.
BTW, run 75w90 or higher gear oil in the trans versus 20w50...will run smoother.
Old 03-20-2010 | 11:17 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on what KBFXDLI just mentioned.
Old 03-21-2010 | 12:16 AM
TDSnowSPR's Avatar
TDSnowSPR
Thanks for all the great info folks....Im gonna read up!!!!
Sean
Old 03-21-2010 | 01:53 AM
TDSnowSPR's Avatar
TDSnowSPR
how can i found out when my Wide Glide was manufactured and if it has the dowel pins or not?
Thanks again folks,
Sean
Old 03-21-2010 | 07:27 AM
RonnR's Avatar
RonnR
PKellyMC link...
https://www.hdforums.com/forum/dyna-...y-bearing.html
Great read
It was an invaluable 'how to' for me...
Heres my story. Thank to Patrick
https://www.hdforums.com/forum/dyna-...ms-i-hope.html
Quick Reply: Just bought a used 2006 Dyna with 3686 on the...
