?? 07 LOWRIDER hEADLIGHT.
Yes, there is a fuse for the lights, but it might just be a loose or pinched connection, or the headlamp bulb might be burned out. I'd start with the bulb and work my way back.
The headlight 4-place multilock connector is located inside the top frame tube. The Fuse block is located under the electrical craddle cover on the left side above the primary cover. The lights fuse is the very last fuse on the bottom right side.
MMIENT...... know of what you speak. Last year, I had HD Fog Lights installed. One day they quit working, but only part of the time. If I sat on the seat, they quit....if I got off the seat, they worked fine. Lifted the seat and found the wires were pinched between the seat and frame close to where the battery was. Moved & retaped the harness, and they've worked fine from that point forward.
Glad to hear it's going to be a simple fix for you.
Do your wife a favor........ change her over to a Sylvania Silverstar or PIAA XTreme White pLUS bulb for Motorcycles. Replacement Size for motorcycles is "H4" and you might be able to pick them up at an automotive parts stores. They sell them online at Amazon.com, ebay etc. and other bike/automotive places, but check shipping costs before you order. Make sure the H4 is listed as a
12V 60/55 = 110/100 type.
I picked the PIAA for my bike. They're a little more expensive than the Silverstar's but they also have "anti-vibration" built into them where the Silverstone doesn't. Both my Dyna and hubby's & Daughters Heritages are all running PIAA'S going on 3 years now with no problems. WHEN YOU REMOVE THEM FROM THE PACKAGE & GO TO INSTALL THEM.......DO NOT TOUCH THE BULB WITH YOUR BARE FINGERS. These are Halogen bulbs and the oils on your fingers will cause them to fail prematurely.
They sure do increase your visibility both at night and to oncoming traffic. It's amazing the difference it made for us.
Here are a couple links.......with owner comments at the bottom
http://www.amazon.com/15224-Style-Xt...=pd_sbs_auto_1
The above is for 2 PIAA bulbs...I know they sell individual bulbs as well.
http://www.amazon.com/Sylvania-H4ST-.../dp/B000AM8BN6
This is for a single Silvania bulb.
