Handlebar Info Thread ...
Dyna Crew ...
Seems there's always a few threads up on bar changes, cables, brake lines, etc ... I thought it might be a good idea if we all post here with the info we have on our set-ups. At your conveience ... post the bars you've installed and all others parts, part #'s, and mods that were needed to get the job done. Maybe we can all save each other some time better spent wrenching and riding.
Thanks all ....
PsTaN
Thanks all ....
PsTaN
06 FXDBI Street Bob -w- Street Slammer Bars
[ul][*] Street Slammer Bar - #56391-04[*] Clutch Cable Black - Stock 06 FXDI #38765-06[*] Throttle/Idle Cables - Stock 06 FXDBI[*] Brake Lines - Diamond Back #46654-06[*]Clutch Cable Guide Kit - NOT NEEDED
[/ul]
Note: Street Slammer Bars will fit with existing cables on FXDIs the HD book says NA due to the gauge mounting - mount the gauges some other way, and your FXDI cables will be fine.
[/ul]
06 FXDBI Street Bob w/ 16" Nash Motorcycle Gimp Hangers
just ordered all this
-Nash Motorcycle 16" Gimp Hangers ($175) - www.nashmotorcycle.com
-Barnett Black Clutch Cable +6 over ($50) - #BA-789-06+6
-Barnett Black Brake Line +6 over ($75) - #HD0073-1FCH/BL+6
-Barnett Black Throttle Cable +6 over ($18) - #BA-343-96+6
-Barnett Black Idle Cable +6 over ($18) - #BA-342-96+6
-Long Beach Sindicate Wiring Harness Extensions ($20) - Long Beach Sindicate (562)572-7405
Yep. Pick up the Wild One Chubby 12.5 Apes. It'll get you 2.5 higher and a bit wider as well. You'll need new cables and lines. I extended my harness, although some say you can dig more out of the frame tube. I didn't see enough slack. When I'm finished with the install (long story), I'll be as specific as possible. In the meantime, check out these two links for internal wiring and a complete ape install (w/pics) on a Road King:
Handlebar Wiring
Apes Install From Start To Finish
Whiff
Handlebar Wiring
Whiff
