Anyone lowered the front fork springs?
Old 03-17-2010, 11:26 AM
09DynaRyder's Avatar
09DynaRyder
09DynaRyder is offline
Question Anyone lowered the front fork springs?
I put the lowered rear shocks on my 09 SG and was thinking about the low profile fork kit from the dealer. Anybody done it? Did it make a noticeable difference in handling/ comfort? I'm skeptical about only a 1" drop being worth it?
Old 03-17-2010, 11:31 AM
GasserNorm's Avatar
GasserNorm
GasserNorm is offline
Can you slide the fork tubes in the trees an inch? It sure would be cheaper and easy to go back if you didn't like it.
Old 03-17-2010, 01:12 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
i did a 1.5 drop on the front of mine with the full progressive kit and cut the spacer and added a bit to the damper. worked out great and i love the ride
Old 03-17-2010, 01:14 PM
lhcstreetbob's Avatar
lhcstreetbob
lhcstreetbob is offline
i did the drop in progressive kit ..it was very easy and the ride is great
Old 03-17-2010, 01:32 PM
Gutter Man's Avatar
Gutter Man
Gutter Man is offline
I lowered the front tubes about 3/4" and screwed the cap on the top of the tube down to the top of the tree. It was free.
Old 03-17-2010, 02:57 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
i am not really sure what you mean when you say you: screwed the cap on the top of the tube down to the top of the tree
Old 03-17-2010, 03:48 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
I did the progressive drop in kit. Simple, easy and works. $100 bucks well spent. Sig pic has both the front and rear drop done together.
Old 03-17-2010, 04:05 PM
BrassHOLE's Avatar
BrassHOLE
BrassHOLE is offline
i actually got the burly slammer drop, i put the rears on yesterday just tryin to talk myself into doin the front.. might i add the rear rides 50% better then the progressive 411 i had
Old 03-18-2010, 12:54 PM
ggadwa's Avatar
ggadwa
ggadwa is offline
Default Anyone Lowered the Front Fork Springs
Yep.... I did the 11 inch Progressive Shocks on the rear and didn't like the rake and the feel. So opted for the Progressive Drop In Front Springs with cutting spacer for 1 inch lower. I've done the Fork slide in the Tree before several times....Works fine really. I do like the ride and handling with the Progressive all the way around. The Drop In kit was cheap and very quick.
GARY
Old 03-18-2010, 01:17 PM
09DynaRyder
Well, i think I'll try sliding the fork tubes a bit to see how that works and then maybe get the actual kit. Thanks for all the replies!
Quick Reply: Anyone lowered the front fork springs?
