illuminated mirrors HD
2 bolts hold that tank on. Disconnect fuel line and remove crossover line. I would advise on not removing it with a full tank it isnt fun, its just heavy. also use some vise grips to keep fuel from running out ouf the crossover line. then unplug the wiring to speedo tach etc, viola tank is off. I wont take long to do even with installing the mirrors. Save it for a crappy day and invite a buddy over to help.
I'm guessing that taking the tank off will make it a lot easier to get to the necessary wiring, however most of those wires in my little bit of experience can be fished out from under the tank. I've found that there was enough extra wiring to achieve what I needed to do. That's what I've done changing out my front signals and wiring, etc.
I dont think it does from what the instructions say. http://www.harley-davidson.com/en_US...ts/-J04401.pdf
probably these. I am planning to get a set as well to do away with the front turn signals.
http://www.harley-davidson.com/gma/g...5&default=none
