Stripping paint
I assume you know that you have to have an air compressor. Anyway, the media comes out of the nozzle and hits the part, then it all gathers at the bottom where it is sucked up through the tube again. Sometimes you have to shake the cabinet to resettle the media. Just trying to provide enough info to help. I highly recommend you go this route. Good luck.
lol... Almost every time I have asked a painter to take it down to the metal I get the same answer, no need, "just scuff cote and spray"...
I can tell you the paint on my new rear fender was not easy to glass bead... Hope it goes well. Have a glass bead cabinet at the shop, barely big enough for the fender, but it worked.
Does the air have to stay connected all the time? I guess you fill the tank with media, then pressurize and away you go. When you run out of pressure, just hook the air line back up. At least that's what I'm thinking is possible.
I'm building a good rapport with the guy, so we'll see what happens.
