03 dyna low bullet install
If your going from the eyebrow top mounted light to the bottom mount on lower triple tree, then you will need to drill a hole for the headlight mount. Remove the front wheel, measure twice and drill once, in the center. Lots have done it. I tried without removing the wheel, but i'm dumb and should have just listened to everyone. Start with a small drill bit as a pilot hole and work your way up.
I tapped a hole in the tripple tree bottom mount so I didn't have a bold on the bottom. I had to use a springer mount to get it far enough away from the frame. I then used a cover from headwinds for the dummy lights.
http://www.headwinds.com/mm5/merchan...ry_Code=010502
http://cgi.ebay.com/ebaymotors/HEADL...Q5fAccessories
Not sure if that is the same mount I used. Definatly a similar one.
drumer66
02-21-2008 08:17 PM
