wiring the rear with no taillight.
Old 03-10-2010, 06:20 PM
justmejohn44's Avatar
justmejohn44
justmejohn44 is offline
Here's What I did may be you can try it... it's in the How to under $50 thread https://www.hdforums.com/forum/6029170-post1389.html
Old 03-14-2010, 10:18 PM
chuckieb's Avatar
chuckieb
chuckieb is offline
I removed my tail light and installed a Run/Turn/Brake harley module and also integrated a sidemount license plate into the mix.
The first module didn't last, it was the harley product. They did replace it though.
Old 03-16-2010, 02:40 PM
RicMF's Avatar
RicMF
RicMF is offline
Alright, I'm working through this project a little bit at a time. Run/brake/turn module and new tails ordered, and rear fender is all smoothed out and primed (just came from the painter's).
I understand how it all fits back together, but I'm not sure about the best way to actually wire it up. What I was *hoping* I could do, was get the male side of the plugs that the turn signals plug into (which is currently a part of the tail light assembly) and connect those to the soon-to-be-butchered wire harness that runs to the plug under the seat. The guy at the parts counter said that'd be great if he could get those for me, but sorry.
I don't mind just cutting and splicing the rear turn signal wires, but if I ever take my rear fender off again, I'll be clipping and re-soldering again. Not to mention I want the wires up nice'n tight and out of the way of the rear tire. Anybody coming up with a slicker way of doing this?
Old 03-16-2010, 04:51 PM
panic_fan's Avatar
panic_fan
panic_fan is offline
My buddy and I both did exactly what you're trying to do. The parts guy was able to find the other half of the two-pole plug for us though. Wish I'd kept the part number. We also ordered the little wire crimpies and an extra male and female plug set for the license plate light. Took the large plug that connects to the R/T/B module (usually runs to the tail light assembly) and paired up the wires to the new plug bodies and snapped in the sigs and license plate.
I recall it was a challenge getting through to the parts guy that we needed the other side of the two-pole plug because the MoCo doesn't have anything on an 08 Dyna that needs it. So it's not in the parts manual for our machines. I had to really explain what we were doing and got lucky when someone knew where to look.
SuperG96
09-22-2016 07:01 AM
izzyryder
01-27-2016 11:16 AM
SouthernGent
11-30-2012 09:11 PM
cjm8806
03-23-2010 02:19 PM
bberck
02-08-2010 06:55 PM
Quick Reply: wiring the rear with no taillight.
