How to Change engine oil?
There are about 50,00 threads on oil change here on this site,unfortunately all opinions seem to differ.some use amsoil in all three, some mobil1, some guys like auto tranny oil in the primary , it all works,it is what it is. Check this link there is a lot of info on that page. https://www.hdforums.com/kbase/
What i do to get the filter off is remove the voltage regulator ( two bolts,) and use a regular auto fiter wrench,being careful around the sensor that sits right beside the filter iself.
You can buy a 15 point cup filter wrench that goes on a ratchet extension at autozone. Take the filter with you cause there is a 15 and a 16 point for car filters. I use Mobil1 20w-50 syn in the motor and the primary and 75w-90 in the tranny but will go to 75w-140 next time. Be a good idea to start out by replacing the T27 torx bolts on the primary cover with 1/4" chrome hex head bolts from the hardware store. Those torx bolts suck. Also I cut a plastic jug out to fit under the filter to catch as much oil as I can from loosening the filter.
If you dont have one yet, go get the service manual for your bike. It will walk you thru step by step on your oil change. Also, there is other items that will need attention at this time, if its a major service interval... Or you just might be changing oil since winter is melting away...
Either way that manual is worth its weight in gold... Can be had for around 60 bucks, the best 60 bucks ever spent on your bike!
I highly recommend synthetic fluids - brand is up to you. I went with Amsoil and, no, you don't use the same stuff in all 3 holes. Synthetic really quietened my tranny and smoothed out my shifting (no more clunks) significantly. As someone said, there are tons of oil related threads here you will find in a search. Go ahead and buy several o-rings for the plug bolts, they are cheap, and change them out every time you pull one of those bolts. And be careful not to damage them when you put the bolts back in. Use a torque wrench and torque to specs (see the recommendation to pickup a service manual).
