Suggestions for Black Pipe Wrap?
The lava wrap looks pretty dark; I used the regular Black wrap and spray painted it with stove paint before I installed the pipes. After the burn in it's a dark gray.
http://www.heatshieldproducts.com/p_lava_wrap.php
ThermoTec and DEI are good, most of them are a dark gray, you have to spray them with the High Temp Silicon spray after you wrap them and let them dry.... it's made for the wrap, made by the same companies... Get the black spray... darkens them right up.... they will turn gray again eventually.
Also, you don't even have to order them, they have all the stuff at Autozone and Advance Auto. Make sure to pick up some stainless steel zip ties also, to fasten them securely
i have wrapped both my dyna and buell head pipes and i use sreamin' eagle on the buell and ebay special on the dyna but used the black silicone spray on both and sitting side by side you cant tell a difference. The trick is a tight wrap that you can really only get if you wrap wet (my opinion) and a second set of hands doesnt hurt either. wear gloves and put down a tarp cause this stuff gets messy. also another thing i used was stainless steal hose clamps (the ones with the screw tightener) these seemed to work alot better for me as i couldnt ever get the regular stainless zipties to work (i think im a little stupid when it comes to those). once everything is dry and painted and back on the bike, start it up outside cause its gona smoke like a frieght train!!! and smell like pancakes (yeah im wierd)?!?!?!
